I have been attempting to follow the instructions at [www.reprap.org] to install the software. It hasn't been working. I was unable to find the RXTX software due to the server being down. I later found another link here in the forum and used that. It went in well.
When I attempted to run the software after installation using "./reprap-host.sh" I get the following output:
at org.reprap.gui.STLObject.(Unknown Source)
at org.reprap.gui.RepRapBuild.createSceneBranchGroup(Unknown Source)
at org.reprap.gui.Panel3D.initJava3d(Unknown Source)
at org.reprap.gui.Panel3D.initialise(Unknown Source)
at org.reprap.gui.RepRapBuild.(Unknown Source)
at org.reprap.Main.createAndShowGUI(Unknown Source)
at org.reprap.Main.access$2400(Unknown Source)
at org.reprap.Main$23.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
I'm not sure if I did something wrong. I have only a fair amount of experience in Linux. I'm using Ubuntu 6.06 LTS the Dapper Drake. I've used this version for quite some time and have no problems with it. I get around quite nicely in it, in fact. I'm fairly certain I followed the instructions correctly--for instance, I verified where my JRE directory was so as to be sure I got things into the right places.
Please help me. I don't know what the problem is.
Thanks
Re: Software Instillation Problems in Ubuntu Daper Drake
August 12, 2007 03:31PM
it appears you dont have the full java3d install. try putting this file in your jre lib dir: (jre/lib/ext i think...)
[svn.reprap.org]
Thanks, fixed the problem.
Cheers!
