Jog Control - Home button ignores feedrate
May 13, 2010 12:09AM
Hi Everyone,
Still working on my junkstrap ('JaqueStrap'). I now have the motherboard, endstops, and the x and y axes mechanically setup.
I am working on calibrating my axes, and it is going well but I have a question about the home function in the Reprap Host XYZ jog panel:
My axes are geared, so I have a much higher steps_per_mm than normal lets call it 3.5:1. As a result of this, I need to lower my feedrates. The X axis moves well at 1500, the Y axis moves well at 1000 - I can change these values in the host software, and it works very well - I get great smooth movement, high precision, and repeatability. BUT - when I hit the Home button - the Reprap Host takes off like a bat out of hell using an unknown feedrate - (3000? 5000?), which my axes don't like at all.
Question 2: Is there somewhere I can modify the XYfastfeedrate that is used by the home function? (Preferably without needing a Java IDE, and recompiling the application?
Thanks!
Re: Jog Control - Home button ignores feedrate
May 13, 2010 06:36AM
Assuming you're using the 5d firmware, it's in the configuration.h file for the motherboard firmware.
May 14, 2010 08:11PM
I figured it out -
I had more than one reprap preferences file, after cleaning up extra files, and restarting the reprap host, it is now using the values stored in the file.
Thanks!
