Anonymous User
Ubuntu USB-Serial port install procedure August 26, 2007 06:58PM |
how to install serialport using java in ECLIPSE WITH AN EXAMPLE September 05, 2007 05:28AM |
how to install serialport using java in ECLIPSE WITH AN EXAMPLE September 05, 2007 05:31AM |
Re: Ubuntu USB-Serial port install procedure September 10, 2007 11:12PM |
Re: Ubuntu USB-Serial port install procedure September 12, 2007 11:17AM |
Re: Ubuntu USB-Serial port install procedure September 29, 2007 01:54PM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Ubuntu USB-Serial port install procedure October 15, 2007 02:39AM |
Re: Ubuntu USB-Serial port install procedure March 25, 2008 10:16AM |
Re: Ubuntu USB-Serial port install procedure April 16, 2008 06:12AM |
Re: Ubuntu USB-Serial port install procedure April 16, 2008 06:17AM |
Re: Ubuntu USB-Serial port install procedure September 05, 2008 10:24AM |
Re: Ubuntu USB-Serial port install procedure March 13, 2009 08:27AM |
Re: Ubuntu USB-Serial port install procedure August 05, 2009 11:32AM |
harsha
Re: Ubuntu USB-Serial port install procedure September 04, 2009 06:32AM |
Re: Ubuntu USB-Serial port install procedure September 30, 2009 08:39PM |
Re: Ubuntu USB-Serial port install procedure November 24, 2009 10:51AM |
Re: Ubuntu USB-Serial port install procedure November 24, 2009 11:55AM |
Re: Ubuntu USB-Serial port install procedure December 15, 2009 10:07AM |
Re: Ubuntu USB-Serial port install procedure December 15, 2009 04:02PM |
Rakesh S Joshi
Re: Ubuntu USB-Serial port install procedure December 16, 2009 04:49AM |
Re: Ubuntu USB-Serial port install procedure January 28, 2010 12:53AM |
Re: Ubuntu USB-Serial port install procedure March 13, 2010 01:16AM |
mm
Re: Ubuntu USB-Serial port install procedure April 09, 2010 02:25PM |
mm
Re: Ubuntu USB-Serial port install procedure April 16, 2010 01:18PM |
mm
Re: Ubuntu USB-Serial port install procedure April 16, 2010 01:28PM |
mm
Re: Ubuntu USB-Serial port install procedure April 16, 2010 01:56PM |
Re: Ubuntu USB-Serial port install procedure May 24, 2010 05:41AM |
Re: Ubuntu USB-Serial port install procedure June 05, 2010 03:17AM |
Admin Registered: 17 years ago Posts: 476 |
mm
does anyone know how to permanently change permissions for /dev/ttyUSB0. Mine keep reverting back.
sudo usermod -a -G dialout $USER(in Ubuntu or Debian, this may need minor changes in other distributions).
mm
Does anyone know how to set the speed for a usb -to serial port?
stty -F /dev/ttyUSB0 9600should set /dev/ttyUSB0 to 9600bps.
stty -F /dev/ttyUSB0 -aand you should get all the details of exactly how that serial port is currently configured, including its speed.
Re: Ubuntu USB-Serial port install procedure July 26, 2010 07:14AM |
Re: Ubuntu USB-Serial port install procedure August 04, 2010 05:59AM |
