how to keep steppers enabled during build February 21, 2011 04:13PM |
Re: how to keep steppers enabled during build February 21, 2011 05:06PM |
// Set these to 1 to disable an axis when it's not being used, // and for the extruder. Usually only Z is disabled when not in // use. You will probably find that disabling the others (i.e. // powering down the steppers that drive them) when the ends of // movements are reached causes poor-quality builds. (Inertia // causes overshoot if the motors are not left powered up.) #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 1 #define DISABLE_E 0
Re: how to keep steppers enabled during build February 21, 2011 06:52PM |
Re: how to keep steppers enabled during build February 22, 2011 01:35AM |
Re: how to keep steppers enabled during build February 23, 2011 09:38AM |
