Problema ramps
Posted by Ramiro14
Problema ramps
November 10, 2019 06:25PM
Hola, estoy armando la prusa dolly de Thomas Sanladerer.
Tengo la impresora armada, ya le cargue el marlin al arduino. Pero al querer calibrarla con el pronterface no puedo hacer que lo motores se muevan.
Ya configure bien los finales de carrera, regule el potenciometro de los a4988 pero sigue igual. Lo raro es que tampoco hacen sonido como que saltan pasos.
Estuve probando otras cosas: la cama calienta bien, los termistores andan, pero el hotend tampoco calienta y tira error.
Todos los a4988 estan alimentados por 5v, pero no tienen tension a la salida cuando pongo que se muevan los motores.
Lo que note tambien es que cuando pongo que la cama levante temperatura, empieza a parpadear un led azul, pero si pongo algun otro comando no parpadea.
Hay alguna forma de probar si el ramps 1.6 funciona bien? O de probar las salidas del arduino?
Saludos.
Re: Problema ramps
November 10, 2019 09:12PM
"All a4988 are powered by 5v,"
a4988 need 5v and a VMOT voltage commonly 12v or 24v volts.
Check you have power connected to BOTH RAMPS power inputs.
5A plugs is for stepper drivers and hot ends + mega when usb is not connected
11A plug is for hotend only,
Edited 2 time(s). Last edit at 11/10/2019 09:15PM by Dust.
Re: Problema ramps
November 11, 2019 06:15PM
Hello, thaks for the answer.
I have the ramps 1.6, It have only 1 conector for the power unit.
reprap ramps 1.6
Checking your diagram, I don't have 12v between vmot and GND. That is the problem, no motor is powered and the extruder does not have tension either
I try a program for arduino that is in reprap (I can't find the link), which tests all the outputs and moves the motors from one side to the other, and they didn't work either.
Re: Problema ramps
November 11, 2019 07:03PM
Ah yes I forgot that the 1.6 has one power plug
It also has surface mount fuses. F1 and F2. check them for continuity
Re: Problema ramps
November 11, 2019 09:58PM
I check both of them and both have continuity
Re: Problema ramps
November 11, 2019 10:11PM
Then it must have a board fault... a break in the 12v or the gnd line that feeds vmot.
Re: Problema ramps
November 12, 2019 07:32AM
Uuuuuuh, thank you very much for the help!
I'm going to buy another ramps today. Do you recomend me to buy the 1.6 again or should I buy the 1.4?
Re: Problema ramps
November 14, 2019 07:02AM
Yo te recomiendo sin dudarlo la 1.6, ir hacia atrás no es buena idea.
Primero por los mosfet, que no estaban muy bien dimensionados en la 1.4.
Segundo por los diodos en las salidas de la cama y fusor, que la 1.4 no los tenía y había retorno.
