hola a todos, espero me puedan recibir en esta gran comunidad.
para empezar tengo una impresora clon china con dos tarjetas melzi ya que es tricolor y en eso de querer actualizar el firmware de las melzi el código no compila en el IDE de arduino y como no se mucho de programación espero me puedan ayudar a salir adelante con este problema que tengo, gracias
les dejo el log de error:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\sanguino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\sanguino\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal C:\Users\Esteban\AppData\Local\Temp\build6271130073872187795.tmp\FPUTransform.cpp -o C:\Users\Esteban\AppData\Local\Temp\build6271130073872187795.tmp\FPUTransform.cpp.o
In file included from /FPUTransform.h:4,
from FPUTransform.cpp:1:
/Marlin.h:35:26: error: WProgram.h: No such file or directory
/Marlin.h:86: warning: only initialized variables can be placed into program memory area
/Marlin.h:87: warning: only initialized variables can be placed into program memory area
/Marlin.h: In function 'void serialprintPGM(const char*)':
Marlin.h:110: error: 'Serial' was not declared in this scope
/Marlin.h: In function 'void serialPrintFloat(float)':
Marlin.h:117: error: 'Serial' was not declared in this scope
/Marlin.h:118: warning: only initialized variables can be placed into program memory area
/Marlin.h: At global scope:
Marlin.h:126: error: variable or field 'manage_inactivity' declared void
Marlin.h:126: error: 'byte' was not declared in this scope
Marlin.h:204: error: 'boolean' does not name a type
FPUTransform.cpp: In function 'void loadMatrix(float, float, float, float, float, float, float, float, float)':
FPUTransform.cpp:21: error: 'Serial' was not declared in this scope
FPUTransform.cpp:24: error: 'Serial' was not declared in this scope
FPUTransform.cpp:28: error: 'Serial' was not declared in this scope
FPUTransform.cpp:32: error: 'Serial' was not declared in this scope
FPUTransform.cpp:56: warning: unused variable 'TranslateX0'
FPUTransform.cpp:61: warning: unused variable 'TranslateY0'
FPUTransform.cpp:79: warning: unused variable 'MatrixStage1'
FPUTransform.cpp:80: warning: unused variable 'MatrixStage2'
FPUTransform.cpp:90: warning: unused variable 'MatrixStage3'
FPUTransform.cpp: In function 'void FPUTransform_init()':
FPUTransform.cpp:129: error: 'Serial' was not declared in this scope
FPUTransform.cpp:133: error: 'Serial' was not declared in this scope
