Delta bots are scalable, I and a few others plan to build a 1 meter 3D printer, and larger.
Our problem today is that the software to drive an inverted delta robot is not able to print accurately.
A few of us are working on the machine design, and more importantly the software.
If your product "fits air" (i.e. accurate reproduction of geometric form and dimensions are not important),
as most external features of a piece of furniture are,
then you probably could use the inverted delta printer software in it's current state.
Accurately = Deviating only slightly or within acceptable limits from a standard.
New arm design for Simpson style printer.
forums.reprap.org]
Grounded Experimental Delta Printer
forums.reprap.org]
I'm curious, no need to answer:
What kind of plastic do you pan to use?
Can you post a picture of the piece of furniture that you want to 3D print?
How many do you want to manufacture?
Is the cost of manufacturing a concern?
Edited 1 time(s). Last edit at 11/03/2013 04:32PM by A2.
