Design considerations for Parts for 3D printing
Posted by bmsweb
October 05, 2011 03:40PM
I was wondering if there are any good links that discuss design do's and don'ts for 3D printing. I haven't even built my printer yet but I'm looking at one of the parts I've designed and I'm not sure if its printable. Any tips, suggestions or links would be much appreciated.
Re: Design considerations for Parts for 3D printing
October 05, 2011 04:44PM
I think that the primary rule is that all overhangs need to be 45 degrees or less.
Large overhangs, even at less than 45, need support structures.
There is also a minimum wall thickness / hole size that most people can print, but that is very printer-dependent.
And of course, print bed volume. This is something you'll need to take into account if you want to make the object more universal, since a lot of people have Makerbots, which have a much smaller volume.
If you're not sure of your design, post it here, or on one of the other forums for comment.
October 05, 2011 04:53PM
Thanks, I will fire up my PC and post a pic of the design here shortly
October 05, 2011 05:11PM
This is the part & I'm assuming the click in sections on the top left and right won't be printable because they are not supported. Is this correct?
open | download - MicroClip.jpg (53.4 KB)
October 05, 2011 05:17PM
+1 for design resource suggestions.
I'm really enjoying designing parts for the printer, and i'm learning a lot on the way (which is the point of doing it of course), but I would love to know if there are any guides, books or such which can help me improve how to think about design.
Quite often I will have an idea and start to throw together a proof of concept only to realise there is something in the design I have overlooked. Most of the time I need a dose of common-sense, or a bit more patience to think through the design, and most times I learn a lot from the process itself, which is all part of the reason to do it in the first place. However, it would be great to know of anything that can help develop the process of designing itself!
I saw the following sketch from a Makerbot blog post the other day which exemplifies the kind of thing I think i'm looking for:
For the engineers and designers out there this may seem simplistic - but this kind of thing can be really useful for the hobbyists amongst us. I would really like to collect these kind of things together over on the development tracker so people starting out can quickly learn how to design for 3D printers.
Cheers,
Gary
garyhodgson.com/reprap | reprap.development-tracker.info | thingtracker.net
October 05, 2011 09:23PM
HI..
I think you may have a problem with overhang. You could add some support when you SF it..
Nice jobby on the desgin, what program did you use
Auzze
October 06, 2011 12:27AM
Thanks Auzze,
I actually realized the problem after designing this clip. I guess I need to start printing to learn the limitation of 3D Printing and work with it.
In any case I am using an Application called Catia V5, its what's used in design engineering in Automotive, Aerospace etc. I use it at work for Aircraft Tooling Design most of which is all focused around Machining drill fixtures etc So this is all very new to me smiling smiley
