My repstrap
Posted by chris...
My repstrap
September 15, 2013 04:13AM
building a repstrap
mechanically unsound but completed
just need the electronics, extuder, hot bed, etc
open | download - reprap3.jpg (372.7 KB)
Re: My repstrap
September 15, 2013 04:29AM
Looking good!
Re: My repstrap
September 15, 2013 05:55AM
It's all metal except the white plastic board
Main issues I can think of are:
1. Z axis is driven only on one side and connected with 3mm aluminium
2. Z rails have no bracing support in the x direction, at least this is fixable
3. Backlash is probably excessive, as it is chain driven.
4. Stepper motors are NEMA24 31kg/cm, just dont crash it
5. None of the nuts have spring washer.
6. Can't see the Y stepper motor mount lasting too long
7. One of the z axis rails mounts is not square, fixed this with washers
Good points
1. It's all made from left over or scrap metal or salvaged from a previous machine. Meaning I had already paid for it.
2. Fix the above problems and itll cut aluminium.
3. All axis move freely
Now I need to buy a hotbed, limit switches, controller board, power supply and stepper drivers. I already have an extruder.
I was thinking an all-in-one board like the RUMBA,
Re: My repstrap
September 15, 2013 06:43PM
Nice work.
> with 3mm aluminium
Do what the old Wades Mendel did and drive both sides using one motor and a belt (or chain in your case) between the Z rods.
> driven.
Keep the chain tight and at least it should get you going. Probably enough to make any bits you might need.
> crash it
If necessary, put a second nut on the back of the existing ones. and tighten the nuts to each other, at least till you get some spring washers.
> long
Make another like it and mount it underneath perhaps? Most motors have screw mount holes on both ends.
> Good points
Sounds like a reasonable choice.
Anyway, welcome! Hope to see you printing soon enough.
PS: What part of Melb/Vic are you in? I'm in Caulfield, and the local hackerspace (where we hold a 3D printing night, twice a month on the 1st and 3rd Monday of the month) is in Hawthorn. The hackerspace is called HackMelbourne. If you're ever nearby, feel free to drop in and say hello.
Re: My repstrap
September 16, 2013 08:42AM
I'll need to construct a fair few things to drive both sides, adding a second stepper motor maybe easier. I might just counter balance it for the moment.
I'll check backlash once its running and see what its like
y motor has no mount holes at the bottom
The machine should be good enough to print plastic parts to build a better machine
Re: My repstrap
September 17, 2013 05:10PM
I just assembled the Crap extruder I ordered.
Its a cheap garbage knock-off of the MK7 stepstruder
