Controller Software
July 09, 2011 10:10PM
Can I ask what people are using for their controller software for the printer?
Any pros/cons with respect to the different controllers?
Re: Controller Software
Just to be clear I don't mean the firmware but rather the Host software.
July 10, 2011 05:48PM
IM using repsnapper to control my ramps PCB running the sprinter software.
but Kliment on the IRC channel has been developing a new host software which is getting some good feedback.
Also im using Skeinforge .41 for generating my gcode.
Hope it helps
July 10, 2011 08:46PM
Skeinforge here, I've had too many problems with the RepRap software.
For printer control I'm using my own software which isn't compatible with any of the standard electronics.
July 11, 2011 04:37PM
I'm a bit confused as to the methodology to print. As I understand it, the CAD/CAM toolchain goes like this:
CAD software
G Code Compiler
Host Software (some programs do both hosting and G-Code compiling)
Firmware
Printer
so some of the options we have are:
CAD software:
Sketchup
Creo Elements / Direct
OpenSCAD
G Code Compiler
Skeinforge
Superskein
Host Software
Pronterface
Combined G-Code Compiler / Host software
Repsnapper
Reprap host software (creative name!) tongue sticking out smiley
Firmware
FiveD
Tonokip
Sprinter
Teacup etc
Printer
Mendel
Prusa
Darwin etc.
Do I have this all correct?
July 11, 2011 08:18PM
HI..
All you need to know is
Openscad/RAMPS/Pronterface/Skeinforge/Sprinter/Prusa
Openscad to desgin your files and save as STL
Pronterface/Skeinforge is the host and gcoder converter, Let me explain, if you use Pronterface and have Skeinforge installed in the Pronterface root dir you can load your STL via Pronterface and they will be converted and loaded ready for you to press print.
RAMPS is the best electrinlics for your printer.
Sprinter is the firmware you use on RAMPS or some others.
These is one printer to have and thats a PRUSA.
IMHO
Auzze
