4 pin opto's
October 07, 2011 04:41PM
Started wiring up our Prusa and found on the sanguinololu board the opto headers only have 3 pins but the optos have 4 wires? Anyone run into this before?
__________________________________________________________________________
Experimenting in 3D in New Zealand
Re: 4 pin opto's
October 07, 2011 08:31PM
Sorted
Re: 4 pin opto's
October 10, 2011 01:44PM
Please explain in case someone else has this issue.
Re: 4 pin opto's
October 10, 2011 02:46PM
There are 2 positive pins that need to be wired together
Re: 4 pin opto's
October 11, 2011 08:57AM
Which wires and what model of opto did you get?
Re: 4 pin opto's
October 11, 2011 05:55PM
It is these opto's Here and the positive pins are the ones wired together, there is a symbol on the end of the opto
Re: 4 pin opto's
October 18, 2011 01:26AM
Hmm not sure whats going on though they don't seem to be working with Sprinter and sanguino at the moment
Re: 4 pin opto's
October 18, 2011 08:42AM
You can measure the signal going into the ATmega with a multimeter. Low is < 1V, High is > 3V.
You want at least a current limiting resistor on the LED side, for an application with LED, see [reprap.org]
These optical interrupters can be attached to a Gen6 directly, because Gen6, unlike all other electronics, has the required resistors on the main board.
Re: 4 pin opto's
October 18, 2011 02:47PM
Hmm but I'm trying to hook them to a Sanguino that only has 3 pins which is why we wired the two + pins together
Re: 4 pin opto's
October 19, 2011 06:10AM
You need an endstop PCB, then. At least two designs are available.
