Azteeg X3 3DP Controller - Single board RAMPS October 31, 2011 11:28PM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 09:41AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 09:42AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 09:56AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 11:39AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 11:50AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 12:04PM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 01:53PM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 02:26PM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 01, 2011 09:12PM |
royco
The Mosfets are those square pads on the lower left corner of the board labeled Q1 Q2 Q3, if my calculations are correct they wont need a heat sink aside from the extra copper pours they have. Power dissipation would be around 0.6 watt for the H-Bed, would be warm to the touch I would assume but should be nothing to the Mosfet( will soak up with a constant on electronic load to confirm that)
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 06, 2011 12:44AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 24, 2011 08:42AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 24, 2011 11:54AM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 24, 2011 12:22PM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS November 24, 2011 06:08PM |
Re: Azteeg 1280 3DP Controller - Single board RAMPS December 09, 2011 04:09PM |
