I have just finished assembling the Stepper Motor Drivers. I found a few minor errors in the build process instructions. In order they are:-
1/ LED1 doesn't fit flush to the PCB. There are a couple of flats on the LED leads that wont go through the PCB holes. The LED is the one from the Mouser parts list. A note in the instructions is needed.
2/ R3. It does not matter which way around it is fitted. In fact, in your photo, it is fitted the wrong way around!
3/ C2 and C8. The lead pitch of the capacitors does not match the PCB. It is not a problem because you can bend the leads. But a warning would be useful.
4/ X1,X2 and X3. The first time X1 and X2 are mentioned it should be X2 and X3, which are the 3pin headers. The second mention of X2 should be X1, the 4 pin connector. Also, I purchased the X1 from Mouser. It comes as a pin strip and needs cutting to length. This is not mentioned.
Thanks to everybody for an excellent set of instructions.
Alvin
