testing motherboard: no debug messages in console March 26, 2010 11:29AM |
Re: testing motherboard: no debug messages in console March 26, 2010 07:31PM |
stty 57600 raw ignbrk -hup < /dev/ttyUSB0; ( cat < &3 & cat > &3; kill $! ) 3<>/dev/ttyUSB0
Re: testing motherboard: no debug messages in console March 26, 2010 07:32PM |
Re: testing motherboard: no debug messages in console March 27, 2010 08:43AM |
Re: testing motherboard: no debug messages in console March 27, 2010 12:38PM |
Loading machine: mendel loading simulator Loading driver: gen3.Sanguino3GDriver Attempting to initialize driver replicatorg.drivers.gen3.Sanguino3GDriver@1ab600f No serial port found. WARNING: RXTX Version mismatch Jar version = RXTX-2.2pre1 native lib Version = RXTX-2.1-7 Reset. No connection; trying to pulse RTS to reset device. Unable to connect to firmware.
Re: testing motherboard: no debug messages in console March 27, 2010 01:20PM |
Re: testing motherboard: no debug messages in console March 27, 2010 06:24PM |
Experimental: JNI_OnLoad called. Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyUSB0 comms: G-code: N0 T0 *26 dequeued and sent [0.000s/-1269727605132ms]
Re: testing motherboard: no debug messages in console March 27, 2010 09:43PM |
Re: testing motherboard: no debug messages in console March 28, 2010 02:40PM |
DEBUG: The distribution preferences file and yours match. This is good. [0.006s/-1269798955118ms] DEBUG: GCode opening port /dev/ttyUSB0 [0.182s/176ms] Experimental: JNI_OnLoad called. Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 Error opening port: /dev/ttyUSB0 DEBUG: bufferQueue: attempt to queue: T0; select new extruder to a non-running output buffer. [2.773s/2591ms] DEBUG: bufferQueue: attempt to queue: M113; set extruder to use pot for PWM to a non-running output buffer. [2.773s/0ms] DEBUG: queueRespond: attempt to queue: M105; get temperature to a non-running output buffer. [2.774s/1ms](etc etc - running)
DEBUG: The distribution preferences file and yours match. This is good. [0.007s/-1269799085406ms] DEBUG: GCode opening port /dev/ttyUSB0 [0.151s/144ms] Experimental: JNI_OnLoad called. Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyUSB0 DEBUG: Attempting to initialize Arduino/Sanguino [0.171s/20ms] comms: G-code: N0 T0 *26 dequeued and sent [4.795s/4624ms](and there it stops)
find / -iname 'ftdi_sio.h'on my system there is no match.
2.6.31-20-generic #58-Ubuntu SMP Fri Mar 12 05:23:09 UTC 2010 i686 GNU/Linux
$ stty 19200 raw ignbrk -hup < /dev/ttyUSB0; (cat < &3 & cat > &3; kill $! ) 3<>/dev/ttyUSB0 bash: syntax error near unexpected token `&'
Re: testing motherboard: no debug messages in console March 28, 2010 10:53PM |
( cat <&3 & cat >&3; kill $! ) 3<>/dev/ttyUSB0
