Reprapdiscount Smart Controller Problem
Posted by NickE
January 23, 2015 10:48AM
I have been using my Reprapdiscount Smart Controller since last May with no difficulties. During a print, the display changed (see attached image) to where the first two lines are fine, but the last two lines show blanks for the first 8 characters and white blocks for the last 12 characters. The menu still functions normally (except you have to know or guess what you cannot see). The SDCard part also functions normally. I swapped the two cables and the problem persisted.
Any ideas on how to fix this problem?
Thank you!
open | download - RRDSmartController_problem_sm.JPG (464.4 KB)
Re: Reprapdiscount Smart Controller Problem
January 28, 2015 05:18AM
I don't know id this helps, but I had this symptom after hooking it up.
It seemed that there are more than one possible identifiers for RRD's in the firmware.
Changeing the type solved my problem, but as it worked fine... I see no real solution.
Or is it possible you regressed the type during a firmware update ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
