The first test (power) passes fine on this board, but I'm having problems with the PIC tests. The debug LED comes on ok. When trying to run the Stepper exerciser the software hangs. With debugging on in the software, it just repeats "Receive error, re-sending: Timeout receiving byte" over and over.
I'm using a vmware machine to boot the reprap dvd iso to use the host software, as gettign it installed on a real machine is proving fairly impossible. I ruled out problems with the VM by booting the iso once on a real machine.
Any ideas?
DEBUG: Opening port /dev/ttyS0 [0.000s/-1216068695873ms]
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
comms: tx 0->8: 0 [0.098s/98ms]
comms: tx 0->8: 0 [0.401s/303ms]
comms: tx 0->8: 0 [0.705s/304ms]
www.flickr.com] (Image of board)
