Duet : Implementation of square delta ? August 05, 2015 05:27PM |
Re: Duet : Implementation of square delta ? August 05, 2015 05:49PM |
Re: Duet : Implementation of square delta ? August 05, 2015 06:21PM |
Re: Duet : Implementation of square delta ? August 05, 2015 07:11PM |
PRZ
David, thanks !
Yes rod length are identical.
Thats is really excellent, I will try
No problem with the calibration routine ?
Re: Duet : Implementation of square delta ? August 05, 2015 11:50PM |
Re: Duet : Implementation of square delta ? August 06, 2015 02:43AM |
lolocaledo
Hello,
I've just received my 2 Duet board. Where can I find information to set it up from scratch ?
Best regards,
Re: Duet : Implementation of square delta ? August 06, 2015 07:47AM |
Re: Duet : Implementation of square delta ? August 06, 2015 09:07AM |
lolocaledo
Hello,
Thank you DC42 for these informations.
I'm waiting for the PanelDue and sensors I ordered to you. Not received yet.
I want to use Duet and PanelDue on Delta Printer that is under construction.
I think I have first to upgrade to you DC42 firmware for Duet ?
Best regards,
I've sent you a PM regarding the tracking status or your order for reasons of data protection. Yes you currently need my fork of the firmware fork to run a delta - even RepRapPro uses my fork for their Fisher delta instead of their own.
Re: Duet : Implementation of square delta ? October 04, 2015 12:34PM |
M665 X15 Y-15 ; Z column is the right column
Re: Duet : Implementation of square delta ? October 04, 2015 01:38PM |
Re: Duet : Implementation of square delta ? October 04, 2015 02:30PM |
