Robotdigg heatbed with 130k thermistor for Duet November 15, 2015 03:42AM |
M305 P0 T130000 B3950 R1000 H?? L??
Re: Robotdigg heatbed with 130k thermistor for Duet November 15, 2015 03:50AM |
o_lampe
I got this round silicone heatbed with "3950" thermistor. It reads 130kOhm at room temp.
Is it faulty?
Because 3950 is the standard 100k thermistor in my book...
How would I configure RRF dc42 firmware to work with it?
Is "H" the zero offset and "L" is the gain?
I remember those two terms as two point calibration parameters.
-Olaf
Re: Robotdigg heatbed with 130k thermistor for Duet November 15, 2015 05:21AM |
Re: Robotdigg heatbed with 130k thermistor for Duet November 15, 2015 10:28AM |
Re: Robotdigg heatbed with 130k thermistor for Duet November 15, 2015 03:59PM |
Re: Robotdigg heatbed with 130k thermistor for Duet November 16, 2015 03:57AM |
Re: Robotdigg heatbed with 130k thermistor for Duet November 16, 2015 05:14AM |
o_lampe
I had a H value of 40, but actually 20 would be best. I had to make a compromise, because of low ambient temperature in my workshop. ( I get temp-error below 10°C )
o_lampe
BTW: I had a 30cm floatglass bed and only 25cm heatpad. The glass cracked after 5min with constant 65°C.
I should have used a aluminum heatspreader too. The hot wire in the silicone sheet creates to many hotspots/ temp-difference.
Where do I get 30cm round borosilicate glass in EU?
