Dedicated Mega2560 R3 just to control multiple heatbeds November 09, 2015 11:29PM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 10, 2015 05:22AM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 10, 2015 09:56AM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 10, 2015 09:26PM |
o_lampe
When you say Mega2560, you actually mean RAMPS?
Ramps only has three MOSFETs, so the SBASE would have to power one bed itself.
The fuses on the Ramps are not suited to drive 3 beds. You'd have to replace the 5A fuse at least.
The traces between 5A power connector and MOSFETs are my next concern.
-Olaf
dc42
You don't need to use a Mega because you need only a few pins. A Uno or Leonardo would be adequate. I prefer the Leonardo because of its separate USB and serial ports.
The mosfets you linked to are not suitable because they are designed for 10V gate drive. Use logic level mosfets instead, e.g. IRLB8743.
Your main problem is that the Arduino controlling the bed doesn't know what temperature has been commanded. You can monitor the PWM form the RAMPS to tell when you are approaching temperature, but the PIDs on the bed control Arduino coupled with the PID in the printer controller will quite likely form an unstable system. Better to have the printer electronics just send the commanded temperature to the bed control Arduino, e.g. over a serial link.
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 11, 2015 03:21AM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 11, 2015 08:02PM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 12, 2015 03:39AM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 12, 2015 04:23AM |
Re: Dedicated Mega2560 R3 just to control multiple heatbeds November 12, 2015 08:32AM |
pugzor
Again David, thank you so much. I might put in the level shifter because for only $5 it'll rule out potential issues with ground noise.
I was looking at Jaycar a bit further and they have a little MOSFET [www.jaycar.com.au] Seems to be a NTD5867NL which has a lower output (still a respectable 20A) but has a Rds(on) of 39 mOhms @ 10V. It's a slightly more expensive option but at $7/piece it's still economical and comes is an easier-to-mount package than a naked TO220.
Would something like that be fine rather than a IRLB8743PbF?
