BIQU MKS SBASE Help
Posted by mildot
BIQU MKS SBASE Help
October 22, 2016 07:01PM
Not sure if anyone can help here but I just got the MKS SBASE 1.3 board off amazon. (Amazon Link)
When I plug it in the lights all light up (attached picture) D7 is brighter then the LEDs on the left all flash in sync (red arrows). I can not get the board to show up in windows. I am tempted to just return it but would like to get my printer back up and running.
Re: BIQU MKS SBASE Help
October 22, 2016 10:59PM
Have you tried to seek info from MKS's GitHub ?
You might want to also go to thread of MKS SBASE 32 bits smoothie compatible from China
October 23, 2016 03:32AM
If this board behaves similar to my RADDS then the flashing is due to sd-card sync issues. It flashes a few times and even the steppers seem to move a bit, but once the sd-card is sync'd it works. ( 5-10 flashes after a cold boot )
There was an FW update for my RADDS that helped a lot against this issue, but I'm not sure what smoothieware can do for you.
October 24, 2016 12:36PM
.ok have you install the ftdi drivers as windows won't see it at all
Edited 2 time(s). Last edit at 10/24/2016 12:39PM by chris33.
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
