So I have my RUMBA controller setup and everything is basically except the SD card.
Checking pins_RUMBA.h file, pin 53 is defined for the full graphics controller.
This is the same pin that RAMPS 1.4 uses. However for RUMBA it dose not appear to work. If I plug the SD card into my RAMPS printer it works but not in the RUMBA.
I notice that in the RAMPS pin file both LCD_SDSS and SDSS are used but is RUMBA only SDSS is used.
I can think of only reasons for this. 1 It is the incorrect pin or 2 the SD Card is formatted incorrectly for the RUMBA controller.
Should the #define LCD_SDSS be used instead of SDSS?
So is pin 53 the correct one?
What format should the SD card be?
thanks.
