How to set up microstep on StepStick using A4988 ?
Posted by trietdao95
August 16, 2017 09:55AM
I'm wondering how to setup 1/16 microstep for the driver. Is it just connect VMOT to all MS pins and all pins to GND?
Re: How to set up microstep on StepStick using A4988 ?
August 16, 2017 10:29AM
All MS(0,1,2) pins high for 1/16th micro-stepping yes, assuming you have a real Stepstick with A4988 - not A4984 which cannot do more than 1/8th.
BUT NOT TO VMOT !!! eye popping smiley
The correct high level for logic inputs is VDD.
August 16, 2017 08:15PM
You have most likely destroyed this stepper controller. the micro stepping pins cant take > 5v.
