Lerdge Extrusion rate
Posted by azx987sa
June 03, 2018 02:37AM
The extrusion rate does not work correctly. If it costs 100% - the flow is normal. If it is necessary to reduce the flow to 99%, the flow of plastic is reduced at times! or completely discontinued. Cura. on marlin the same gcode stream can be adjusted very accurately. What could be the problem?
80% -99% there is no difference
99% -100% big difference
100% -300% minimum difference
open | download - CgAGe1mxH_CALSuqAASRimBY4Mk506.jpg (156.2 KB)
open | download - IMG_0311-2.jpg (410.5 KB)
