Anyone have a link to a MKS Gen_L V1.0 wiring diagram? I need to see why my E0 is not powering my extruder. Using the connector from X or Y connectors turns the extruder but not the E0 connector.
when you test the extruder do you heat up the hotend, there a fail safe which prevents the extruder from turning when the temp below 170C, there also a Mcode to allow for cold extrusion you need to send first "cant remember it off hand".
