MKS Gen_L V1.0 Wiring Diagram
Posted by DivePADI
June 15, 2018 02:23PM
Anyone have a link to a MKS Gen_L V1.0 wiring diagram? I need to see why my E0 is not powering my extruder. Using the connector from X or Y connectors turns the extruder but not the E0 connector.
Re: MKS Gen_L V1.0 Wiring Diagram
June 16, 2018 02:57AM
when you test the extruder do you heat up the hotend, there a fail safe which prevents the extruder from turning when the temp below 170C, there also a Mcode to allow for cold extrusion you need to send first "cant remember it off hand".
June 18, 2018 03:18AM
with respect Amazon is not the cheapest source! Ali store and users be buying directly from makerbase.
June 18, 2018 05:25AM
He is spamming us with his amazon affiliate links.
GO AWAY tysonwave you turd.
