Reprap firmware Radds servo/bltouch does not deploy November 20, 2017 04:37PM |
M307 H3 A-1 C-1 D-1 M558 P4 X0 Y0 Z1 H3 F120 T5000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
Re: Reprap firmware Radds servo/bltouch does not deploy November 20, 2017 06:13PM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 21, 2017 03:31AM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 21, 2017 01:59PM |
dc42
What is PWM1 on the RADDS normally used to control?
o_lampe
Did you know, you have to feed external 5V to the "servo connector" block on RADDS? There's a label for 5Vin...
Without that, the servo will not work.
Re: Reprap firmware Radds servo/bltouch does not deploy November 21, 2017 04:14PM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 21, 2017 07:42PM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 22, 2017 02:35AM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 26, 2017 02:02PM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 26, 2017 02:55PM |
Re: Reprap firmware Radds servo/bltouch does not deploy November 26, 2017 05:46PM |
Re: Reprap firmware Radds servo/bltouch does not deploy May 04, 2018 09:44PM |
Re: Reprap firmware Radds servo/bltouch does not deploy May 05, 2018 04:03AM |
Re: Reprap firmware Radds servo/bltouch does not deploy May 05, 2018 08:06AM |
Re: Reprap firmware Radds servo/bltouch does not deploy July 12, 2018 01:25PM |
