MKS BASE
Posted by Roberts_Clif
MKS BASE
March 22, 2019 10:47AM
Today I will start my investigation into the fact that the Hictop Controllers are in fact a MKS BASE Shown Below.
This controller is a Ramps 1.4 Compatible controller but is a MKS Controller because it uses the Mosfet Pin 7 to power the 2nd extruder.
{pins_MKS_BASE.h}
// Power outputs EFBF or EFBE
#define MOSFET_D_PIN 7
If what I believe is in fact true then by changing Marlin from.
{Configuration.h}
#define MOTHERBOARD BOARD_RAMPS_14_EFB
//TO
#define MOTHERBOARD BOARD_MKS_13
This would indeed give me my 2nd extruder but this would also give me controls for a laser adapter
{pins_MKS_BASE.h}
// M3/M4/M5 - Spindle/Laser Control
#define SPINDLE_LASER_PWM_PIN 2 // MUST BE HARDWARE PWM
#define SPINDLE_LASER_ENABLE_PIN 15 // Pin should have a pullup!
#define SPINDLE_DIR_PIN 19
Asking for input from Hictop users if anyone knows for sure that I have come to the correct conclusion.
Re: MKS BASE
March 22, 2019 12:03PM
Took the honors an flashed onto a Old Controller that has a Bad Stepper Motor Driver
#define MOTHERBOARD BOARD_MKS_BASE_14 // MKS v1.4 A4982 stepper drivers
I started up with the setup of Extruder Fan Bed Fan, Tested the Fans and it controls both fans.
I can now flash one of my 3D Printers with this New Firmware Label "HicBlu MKS" this will tell me which version software is loaded.
" I think I have also learned that there are different A4982SLPT stepper motor Driver Chips "
" AS SHOWN Here in Marlin 2.0.0 Firmware module Boards"
"#define BOARD_MKS_BASE_14 404 // MKS v1.4 A4982 stepper drivers"
"#define BOARD_MKS_BASE_15 405 // MKS v1.5 with Allegro A4982 stepper drivers"
" So maybe I did not mess up on my soldering when I replaced the chip other than I purchased maybe the wrong chips "
If this is true maybe can change the firmware to fix.
Edited 4 time(s). Last edit at 03/22/2019 01:00PM by Roberts_Clif.
