Stepper motor sensors getting no power
Posted by stmaus
August 10, 2008 06:42PM
I've successfully built my three stepper boards and when I run the motor check it seems fine. I have noticed though that as the board heats up I get a little glitchy action from the motor that goes away as I blow on the heat sink. Guess I'll need a fan.
Anyway, the problem I'm having is that two out of three of the boards is not supplying the needed 5v to my min/max sensor jacks. I seem to have checked everything but since the other tests say the board is fine I don't know what to do.
Has anyone else run into this, and if so, how did you fix it?
sid
Re: Stepper motor sensors getting no power
August 10, 2008 08:24PM
Check your powersupply first!
If you haven't any cold joints the 5V are simply passed from the powersupply directly to the pins.
(the leftmost cable of the powerjack)
It's a good idea to check C5 and C8 too maybe you short some circuit.
'sid
See layout:
[www.flickr.com]
(vcc is what you're looking for)
August 10, 2008 10:55PM
If the main 5V was the problem then the card wouldn't work at all.
And C5 and C8 on both boards are fine.
It's odd that it's affecting two boards at once.
August 11, 2008 05:16AM
I had problems with two of my stepperboards, too. The problem was that I set them to Slave - without connection the sync-lines.
So make sure all the Master/Slave jumpers are set to Master - and don't connect the sync-lines, you don't need them...
August 11, 2008 06:17AM
Ah-hah! That's exactly how I have my boards set!
It seemed the correct thing to do but I'll try your changes today and post back soon.
Thanks!
August 11, 2008 02:10PM
Try some thermal compound smiling smiley
[en.wikipedia.org]
August 11, 2008 04:55PM
It turns out my problem was more serious than mere jumper settings.
When I looked closely at the board I found that the circuit running between the C6 and POT that should supply voltage to the two sensor jacks had completely delaminated.
It is the exact same mistake on both boards which leads me to believe it is a manufacturing defect. I don't know why I didn't spot it sooner.
I've e-mailed Zach about it and hope he can help.
August 11, 2008 05:04PM
Wow! He's fast!
Got a message from Zach that he can send me the replacements.
Thanks Zach!
