What Size Electronics Cooling Fan? Mains switch wire gauge? November 05, 2019 01:20AM |
Re: What Size Electronics Cooling Fan? Mains switch wire gauge? November 05, 2019 02:03AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: What Size Electronics Cooling Fan? Mains switch wire gauge? November 07, 2019 08:08PM |
Dust
200watt on 12v is 16.6666667amps (NB I very much doubt the SKR 1.3 can drive this directly, you probably need a external mosfet)
From this chart [assets.bluesea.com]
14awg should be fine
AWG # Diameter (mm) Diameter (inch)
12 2.0525 0.0808
14 1.6277 0.0641
Use silicone sleeved wires, with lots of strands, very flexible. Often used used in RC gear.
As for mains... depends on your countries mains voltage
Although it is higher voltage its lower current.
For here its 240vac. I just get a pc power cable from a local reputable store and cut off the plug im not using (but you always check phase, neutral and earth are the colours you expect)
Cable is marked as 1mm2 (copper)
