Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 09, 2020 02:44PM |
SENDING:M122 Testing X connection... Error: All LOW Testing Y connection... Error: All LOW Testing Z connection... Error: All LOW Testing E connection... Error: All LOW
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 09, 2020 10:33PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 10, 2020 05:38AM |
PIN: 0.02 (A 2) Analog in = 1011 Input = 1 PIN: 0.03 (A 3) Analog in = 860 Input = 0 PIN: 0.15 SCK_PIN Input = 0 PIN: 0.16 Input = 1 PIN: 0.17 MISO_PIN Input = 1 PIN: 0.18 MOSI_PIN Output = 1 PIN: 1.18 Output = 1 PIN: 1.19 Output = 1 PIN: 1.20 Output = 0 PIN: 1.21 Output = 0 PIN: 1.23 SDSS Output = 1 . SERVO0_PIN Output = 1 PIN: 1.30 (A62) Analog in = 511 Input = 0 PIN: 1.31 (A63) Analog in = 706 Input = 0 PIN: 2.06 Input = 0 PIN: 2.11 Input = 1 PIN: 3.25 Input = 1 PIN: 3.26 Input = 1 PIN: 4.28 Input = 0
PIN: 0.02 (A 2) Analog in = 1002 Input = 1 PIN: 0.03 (A 3) Analog in = 927 Input = 0 PIN: 0.15 DOGLCD_SCK Input = 0 . SCK_PIN Input = 0 PIN: 0.16 DOGLCD_CS Output = 1 PIN: 0.17 MISO_PIN Input = 0 PIN: 0.18 DOGLCD_MOSI Output = 1 . MOSI_PIN Output = 1 PIN: 1.18 SD_DETECT_PIN Analog in = 0 PIN: 1.19 STAT_LED_RED_PIN Output = 0 PIN: 1.20 STAT_LED_BLUE_PIN Output = 0 PIN: 1.21 SDSS Analog in = 0 PIN: 1.23 SERVO0_PIN Output = 1 PIN: 1.30 (A62) Analog in = 569 Input = 0 PIN: 1.31 (A63) BEEPER_PIN Output = 0 PIN: 2.06 DOGLCD_A0 Input = 1 PIN: 2.11 BTN_ENC Analog in = 0 PIN: 3.25 BTN_EN1 Input = 0 PIN: 3.26 BTN_EN2 Analog in = 0 PIN: 4.28 Input = 1
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 10, 2020 07:24AM |
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 10, 2020 08:03AM |
Dust
Doesn't look like any issues there...
The SD card is moved to the one on the LCD so the SDSS pin changed.
The next suspect is SPI..
Both LCD and the Stepper drivers use SPI...
I know there are different modes for SPI, I wonder if the LCD uses a different one to what is required by the steppers..
Sadly I don't know how to check this...
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 10, 2020 01:01PM |
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error March 11, 2020 01:05AM |
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error May 16, 2020 10:27AM |
Re: Azteeg x5 GT with BSD2660 and miniViki Wifi not working together: TMC connection error May 17, 2020 03:27PM |
