MKS DLC 2.0 disconnected of TFT35 and not upgraded by USB
Posted by asasergio
February 05, 2021 05:34PM
I have two new Makerbase MKS DLC 2.0 cards, and both have the same problem: they do not connect with the TFT35 display and are not recognized by the USB port.
Makerbase claims that the MKS DLC supports updating via USB (Windows 10) and I tried to update the firmware (GRBL) via XLoader but this application does not recognize the DLC: "Can't open port". The OpenBuilds application is also unable to connect to the DLC: "Port error: Opening COM9: File not found".
The DLC has two LEDs, one red always on and one blue always flashing.
I updated, via the SD card, the firmware for CNC and Laser on the TFT35, which seems to be working normally in both versions.
Where am I going wrong?
Re: MKS DLC 2.0 disconnected of TFT35 and not upgraded by USB
February 05, 2021 10:41PM
"xLoader - Microsoft Windows Tool for Flashing CC01, CR01, CR02 or CR03 using IP01"
ie you need a [github.com] for this tool
uploading via usb would use avrdude or AVRDUDESS
February 06, 2021 09:37AM
Hi Dust.
I appreciate your suggestion.
It does not seem to need IP01 for MKS DLC, which has its own USB port.
It is basically an Arduino Uno although the Arduino IDE does not recognize the board either.
I think Windows is installing the wrong driver but I can't find an appropriate driver.
MKS DLC Features
- CPU is ATMEGA328P-AU, 8bit 20MHZ, 5V logic level, stronger anti-interference type...
- Support Laser and CNC...
- Dupport writing machine...
- Support MKS TFT24/32/35 connect by AUX-1, and TFT_CNC firmware support Laser mode and CNC mode...
- Support grbl firmware...
- Support update firmware by USB...
- Support upload firmware hex file by Xloader...
Edited 4 time(s). Last edit at 02/06/2021 09:51AM by asasergio.
February 06, 2021 06:19PM
It uses a standard ch340 usb/serial interface chip.
Drivers can be found here [sparks.gogo.co.nz]
