Hi All,
i finally managed to solder my sanguino kit from Zach.
I tried to upload the upload_test sketch to see if everything is ok.
on my Macbook with Arduino12 i get an error message, saying that another device is using the serial port, same on windows, It says COM4 is in use by an other programm. But there is no other programm running in both cases...
The power led is on, but very dimm as soon as i plug in the usb cable, it comes on bright as soon as i switch to USB power on the sanguino.
is here something wrong with the sanguino hardware ( dry solder point?? ) or is this software related?
can please someone help?
cheers,
Torsten
error message:
Binary sketch size: 1422 bytes (of a 63488 byte maximum)
processing.app.SerialException: Serial port '/dev/tty.usbserial-FTALE6IC' already in use. Try quiting any programs that may be using it.
at processing.app.Serial.(Serial.java:140)
at processing.app.Serial.(Serial.java:72)
at processing.app.Uploader.flushSerialBuffer(Uploader.java:66)
at processing.app.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:73)
at processing.app.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:48)
at processing.app.Sketch.upload(Sketch.java:1632)
at processing.app.Sketch.exportApplet(Sketch.java:1701)
at processing.app.Editor$41.run(Editor.java:2004)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
