Getting a L298 onto strip board
Posted by zignig
October 21, 2008 07:29AM
Hey all,
I have just got boris [puree.interthingy.com] flashing _both_ leds. smiling smiley
Has anyone managed to get a L289 onto strip board ?
[triindia.co.in]
This is the driver used in the Stepper Controller 1.1 , I was going to directly attach two directly to the atMega64 so I could get more control via software.
Just wondering rather than re-inventing the wheel.
Simon
Re: Getting a L298 onto strip board
October 21, 2008 10:47AM
The L298N? Sure, several years ago. You just have to be careful with the strip traces that carry the power output from that chip. I used wire jumpers between the power output pins and the screw terminals that I used to hook the power to the steppers with lots of solder between the pins and the wire jumper to make sure that there was enough conduction material to do the job.
I figured that out after frying a few stripboard strips. You also have to be careful with those diode connections and make sure that your ground from the power end of your board isn't depending on stripboard strips, too. eye popping smiley
October 21, 2008 07:59PM
Thanks Forrest,
So from your reply I glean Strip Board will not take the current (I hate magic smoke smiling smiley ) to drive the motors (17 NMEA VEXTA steppers).
I suspect that multicore wire soldered directly pin to pin on the power side of the bridge would do the job, or even soldering naked wires along the lengths of the track would be even better for heat sinking.
On a side note, some of the Vorroni work that you are doing is very cool. I see that you are using a finite element approach (mmm more RAM). You may want to look at run length encoding the zones in both X and Y axes that way you can just deal with the edges of the zone. You also may want to look at post-processing your 'abstract art' and relax the edges based on an optimization variable (curent for example) this would have to be done away from the pin areas. .....aaanyway , like I said, very cool.
Cheers for advice , back to BORIS and more soldering.winking smiley
p.s if anyone wants alternate photos of BORIS, speak up and I will post more.
October 21, 2008 11:02PM
zignig Wrote:
> Thanks Forrest,
I was running some motors that were pulling right at 2 amps/phase. I fried a few traces on startups.
> heat sinking.
In most cases just filling the trace with solder did the trick. I got to the point of using about #22 single core pin-to-pin to cover the power tracks and ground connections just to be safe.
I don't like magic smoke, either.
One word of caution. Those diodes with the L298N. Make sure you have them hooked up absolutely correctly before you put power to the board. I had some exciting times learning that. eye popping smiley
RAM's cheap on a PC. Any time I can substitute RAM for code complexity, I'll do it.
> You may
Too complicated. I like code so simple that I can come back to it in a couple of years and understand what I did in no longer than an hour or two.
I solved the current problem by making sure that Tommelise's steppers don't draw more than an amp at 12v and most times don't draw more than half an amp. I respect the L298N, but it's too dangerous to let a bright 12 year old fool with because of the high amperage levels. As a result, I use the much cheaper SN754410 which can handle 1.1 amps/phase max. It's pretty hard to get that one to do magic smoke. spinning smiley sticking its tongue out
> said, very cool.
I'm looking at some post processing and on-the-fly optimization schemes that will cut down the tool path length and preserve traces, as is, that need to stay minimalised, like the ones to the clock crystals and USB connections.
Yes, I want alternate Boris pics. Post more and ask Adrian to include you on the Builders Blog so that you can post more formally.
Edited 1 time(s). Last edit at 10/21/2008 11:06PM by Forrest Higgs.
