Gen 6 Heater current
February 21, 2013 06:05AM
Hey all,
Im running a Gen 6 board and have just purchased a Buda style hotend which uses a ceramic heater.
This one in fact - [www.ebay.com.au]
Will my board be able to power that heater?
(should have confirmed before I purchased...)
Cheers
Ash
Re: Gen 6 Heater current
February 21, 2013 10:11PM
So no one knows what the max heater output on this board is?
I've emailed Maker-Farm for no response...
February 22, 2013 06:56AM
just google the heater mosfet part number. should help
February 22, 2013 08:25AM
Your link is missing, so we cant see it.
February 23, 2013 06:59AM
Don't know what happened to the link, its the Buda nozzle that gadgets3D sell.
February 23, 2013 11:15AM
Presuming the FET used for the extruder is the same as that used for the heated bed, you should be fine. Although a bit more of a pain in the ass to find than I'm used to from the past 30 years of specifying components for far more serious endeavors, it appear the nozzle in question uses a 4.7 ohm resistor as the heater, which @12V source works out to a bit over 2.5A continuous. (ie, at 100% duty cycle, or the max current you should ever expect to see in the heater unless it faults)
Again, PRESUMING, as noted above. You're on your own if any of the presumptions don't match your setup.
February 24, 2013 07:29PM
Yeah none of that matches..lol
The heater is a 40W Ceramic type, not a 4.7ohm resistor, as stated in my original post.
I also dont have the Gen 6 deluxe so there is no heated bed FET or output.
[gadgets3d.com]
Cant believe it is so hard to find info like this..
February 25, 2013 06:33AM
Sorry, I realized that you said "ceramic heater" but although I went out of my way to check the gadgets site after you left out the link to that nozzle, for whatever reason, it was not showing the product details when I visited it, just a short description that had no device characteristics, which is why I looked elsewhere. The only reference I could find was the BOM on the Buddaschnozzle site in the UK, which referenced a 4.7 ohm My bad.
ah...40W. so 40/12 = ~3.4 A max with a 12V peak PWM source. That was easy.
So, you need a FET drive circuit that can support that. Just use the same type used for the heated bed.
Edited 1 time(s). Last edit at 02/25/2013 06:54AM by xiando.
February 25, 2013 03:09PM
> this..
There is the wiki entry [reprap.org]. It says heater output, 4A.
February 27, 2013 05:19AM
Thanks, appreciated.
Not sure how I missed that line on the Wiki.. confused smiley
