Temperature drop from 208 to 195 April 03, 2013 12:22PM |
Admin Registered: 12 years ago Posts: 3,096 |
Re: Temperature drop from 208 to 195 April 03, 2013 12:39PM |
Re: Temperature drop from 208 to 195 April 03, 2013 12:57PM |
Re: Temperature drop from 208 to 195 April 03, 2013 02:51PM |
Re: Temperature drop from 208 to 195 April 03, 2013 03:05PM |
Re: Temperature drop from 208 to 195 April 03, 2013 04:17PM |
Re: Temperature drop from 208 to 195 April 03, 2013 04:41PM |
Re: Temperature drop from 208 to 195 April 03, 2013 04:56PM |
Re: Temperature drop from 208 to 195 April 03, 2013 05:46PM |
Re: Temperature drop from 208 to 195 April 03, 2013 06:03PM |
Re: Temperature drop from 208 to 195 April 03, 2013 06:17PM |
Re: Temperature drop from 208 to 195 April 04, 2013 09:01AM |
// PID settings: // Comment the following line to disable PID and enable bang-bang. // #define PIDTEMP #define BANG_MAX 256 // limits current to nozzle while in bang-bang mode; 256=full current #define PID_MAX 256 // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 256=full current #ifdef PIDTEMP //#define PID_DEBUG // Sends debug data to the serial port. //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature // is more then PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max. #define PID_INTEGRAL_DRIVE_MAX 255 //limit for the integral term #define K1 0.95 //smoothing factor withing the PID #define PID_dT ((16.0 * 8.0)/(F_CPU / 64.0 / 256.0)) //sampling period of the temperature routine // If you are using a preconfigured hotend then you can use one of the value sets by uncommenting it // Ultimaker #define DEFAULT_Kp 76.38 #define DEFAULT_Ki 3.50 #define DEFAULT_Kd 416.74
Re: Temperature drop from 208 to 195 April 04, 2013 02:19PM |
Re: Temperature drop from 208 to 195 April 04, 2013 03:18PM |
Re: Temperature drop from 208 to 195 April 04, 2013 05:25PM |
Re: Temperature drop from 208 to 195 April 04, 2013 05:32PM |
Re: Temperature drop from 208 to 195 April 05, 2013 01:46AM |
Re: Temperature drop from 208 to 195 April 05, 2013 03:57AM |
Re: Temperature drop from 208 to 195 April 05, 2013 04:46AM |
Re: Temperature drop from 208 to 195 April 05, 2013 07:51AM |
Re: Temperature drop from 208 to 195 April 05, 2013 01:09PM |
Re: Temperature drop from 208 to 195 April 05, 2013 03:43PM |
Re: Temperature drop from 208 to 195 April 05, 2013 04:47PM |
Re: Temperature drop from 208 to 195 April 06, 2013 06:43AM |
Re: Temperature drop from 208 to 195 April 07, 2013 11:10AM |
Re: Temperature drop from 208 to 195 April 08, 2013 02:59PM |
echo: cold extrusion prevented
Re: Temperature drop from 208 to 195 September 21, 2015 01:19AM |
Re: Temperature drop from 208 to 195 September 21, 2015 05:43AM |
Re: Temperature drop from 208 to 195 September 21, 2015 02:17PM |
Re: Temperature drop from 208 to 195 September 21, 2015 06:48PM |
