Re: Temperature drop from 208 to 195
September 21, 2015 10:15PM
I'ts generally a bad idea to try to connect two power supplies (or two separate outputs from one supply) in series, especially if they are rated for different output currents.
September 22, 2015 01:31AM
villainous
The power supply I have has two outputs, so if I were to tie them together theoretically I could get 24V into the printer.
In addition to dentist's point, it is also quite likely that the 2 outputs of your power supply are not galvanically isolated from each other, so that they share a common ground. In this case trying to combine them in series would result in a short.
September 22, 2015 05:31AM
Most RAMPS boards have capacitors rated at 16V, so you can't use 24V supplies with them except on the bed heater circuit. Can you change the resistor?
