Firmware to drive X-Y galvanometer April 06, 2013 02:17AM |
Re: Firmware to drive X-Y galvanometer April 06, 2013 09:32AM |
Re: Firmware to drive X-Y galvanometer April 06, 2013 03:20PM |
Re: Firmware to drive X-Y galvanometer April 06, 2013 04:08PM |
Re: Firmware to drive X-Y galvanometer April 06, 2013 05:26PM |
Re: Firmware to drive X-Y galvanometer April 06, 2013 08:12PM |
Where regular Reprap would output a step pulse to a stepper, we can just increment (or decrement) the current position and output the new position to the DAC. Getting a clean +/-10V output may take a little electronics, not really my field but I can probably find that somewhere.|
Re: Firmware to drive X-Y galvanometer April 06, 2013 09:20PM |
Re: Firmware to drive X-Y galvanometer April 08, 2013 06:16AM |
Admin Registered: 18 years ago Posts: 14,165 |
Re: Firmware to drive X-Y galvanometer April 08, 2013 11:46PM |
Re: Firmware to drive X-Y galvanometer April 09, 2013 02:15AM |
Re: Firmware to drive X-Y galvanometer April 10, 2013 06:09PM |
Scan Rates: 1 kpps to 30 kpps
XY Resolution: 12 Bits
Color Resolution: 5 bits (for a total of 32,768 colors)
Colors: Red, Green, Blue outputs
TTL Shutter Output
ILDA-standard differential +/-10V 12-bit X and Y output. Adjustable to get as close to the spec as possible.
2 0-5V single-ended 12-bit analog/ttl laser channels (Channel A and
1 5V single-ended ttl laser channel. (Channel C)*
Interlock connector (INTL)*
Without transfer optimizations the unit is able to drive all channels at full resolution up to 64Kpps. This rate could be increased by general optimizations to the transfer protocol or by reducing the number of output channels/resolution for custom applications.
LPC1343 Microcontroller running at 72Mhz.
I am quite convinced the galvo idea is completely doable, and all the components are already available, it is just a question of integration and a bit of software. I think I can adapt my "old" Darwin printer to provide the mechanics.|
Re: Firmware to drive X-Y galvanometer April 11, 2013 12:01AM |
Re: Firmware to drive X-Y galvanometer April 11, 2013 04:28AM |
Re: Firmware to drive X-Y galvanometer April 11, 2013 02:29PM |
Re: Firmware to drive X-Y galvanometer April 13, 2013 06:09PM |
Re: Firmware to drive X-Y galvanometer April 15, 2013 03:23AM |
Re: Firmware to drive X-Y galvanometer April 15, 2013 05:49PM |
Re: Firmware to drive X-Y galvanometer April 16, 2013 02:13AM |
Re: Firmware to drive X-Y galvanometer July 24, 2013 07:50PM |
Re: Firmware to drive X-Y galvanometer July 25, 2013 02:59AM |
Re: Firmware to drive X-Y galvanometer July 25, 2013 05:28AM |
.....im looking for start my sla printer, but have a lot of dudes..
and my bud english...|
Re: Firmware to drive X-Y galvanometer July 25, 2013 05:44AM |
Re: Firmware to drive X-Y galvanometer July 25, 2013 04:32PM |
Re: Firmware to drive X-Y galvanometer August 14, 2013 03:18PM |
Re: Firmware to drive X-Y galvanometer February 27, 2014 03:57PM |
Re: Firmware to drive X-Y galvanometer April 21, 2014 01:30AM |
Re: Firmware to drive X-Y galvanometer April 21, 2014 04:29PM |
Re: Firmware to drive X-Y galvanometer May 15, 2014 06:13AM |
Re: Firmware to drive X-Y galvanometer May 16, 2014 04:34PM |
Re: Firmware to drive X-Y galvanometer June 03, 2014 12:11AM |
