nophead's vitreous enamel resistors
February 24, 2009 02:06AM
since I can't seem to post comments to nopheads blog (the captcha just says "Loading..." and never loads) I'll ask here in the forum:
where did you get the resistor pictured here? what is the part number?
[hydraraptor.blogspot.com]
I can't seem to find anything equivalent on all the usual sites (digikey, jameco) but mouser did have something similar:
[mouser.com]
But I'd rather not make an order to mouser just for a resistor.
Re: nophead's vitreous enamel resistors
February 24, 2009 05:14AM
Hello fenn,
No idea why you can't comment on my blog, others can.
I got them from RS [uk.rs-online.com]
Farnell also list them but they seem to have stopped selling them. It may just be a bug in their web catalogue. It shows the non ROHS version with a link to a replacement, but it actually links to a 4R7.
The Mouser one is longer and thinner and a lower wattage but may work if you make the aluminium block longer.
February 24, 2009 10:09AM
Nop: I am not able to comment on your blog, either. When I try, a captcha window drops down and says that it is loading the sequence that I am supposed to type in to preclude spamming.
The problem is that the sequence never loads and you just wait indefinitely. I tried to comment with both Firefox and Internet Exploder and got the same result.
You might want to look into that.
Hell, there are no rules here - we're trying to accomplish something.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
Thomas A. Edison
February 24, 2009 10:52AM
Yes it seems to be broken at the moment but it was working a few days ago as I have to fill in capchas if I am not logged in. Also somebody posted anonymously this morning so they should have had to use a captcha.
I do know Google had some problems with email this morning.
Presumably if you log in to blogger it will work?
February 24, 2009 10:58AM
Nope, still broken. sad smiley
Thomas A. Edison
February 24, 2009 11:15AM
I have turned off captchas so it should work now.
February 24, 2009 11:37AM
It does.
Thomas A. Edison
February 24, 2009 08:36PM
I think digikey does carry these. I put "RWM" into digikey's search, and seemed to come up with the same (Vishay, up to 450 deg C.) resistors
the digikey p/n is RWMB-6.8CT-ND
the mfgr's p/n is RWM06226R80JA15E1
This part is avail in min quantity of 5. There's another p/n (cheaper) per resistor, but 250 min order.
Larry Pfeffer,
My blog about building repstrap Cerberus:
[repstrap-cerberus.blogspot.com]
