avrdude: stk500_getsync(): not in sync: resp=0xed June 21, 2013 02:07AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 05:23AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 06:16AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 06:51AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 06:53AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 07:04AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 07:37AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 07:43AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 07:48AM |
In file included from heater.cpp: 28: / pins.h: 674:2: error: # error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
Those that can read have a definite advantage!
Re: firmware problem(s) and nozzle jammed June 21, 2013 07:50AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 09:13AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 09:39AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 10:49AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 11:06AM |
Re: firmware problem(s) and nozzle jammed June 21, 2013 12:25PM |
Re: avrdude: stk500_getsync(): not in sync: resp=0xed June 21, 2013 06:09PM |
Re: avrdude: stk500_getsync(): not in sync: resp=0xed June 22, 2013 07:11AM |
Re: avrdude: stk500_getsync(): not in sync: resp=0xed June 22, 2013 11:27AM |
Re: avrdude: stk500_getsync(): not in sync: resp=0xed June 24, 2013 03:12AM |
ralph80
and changed the setting in the bautrate to 38400 in board.txt and in the serialport to 384000 (default 587000)
and changed the setting in the baudrate to 38400 in board.txt and in the serial port to 38400 (default 58700)
Re: avrdude: stk500_getsync(): not in sync: resp=0xed June 27, 2013 05:15AM |
