controller built on breadboard
Posted by Anonymous User
Anonymous User
March 17, 2009 05:38PM
Hi, all
I finished my first stepper controller board, so I figured I'd share it.
It's basically the rrrf 1.2 controller but with two L298s to provide up to 4 amps of current (although the diodes are only 3A so I don't know if they'll like that).
I wired it up using breadboard since there was no availability of PCBs from rrrf (and due to the design change).
Please please please realize that I'm a rank novice at this stuff - there may be mistakes and poor or strange design choices. I would love to hear about them and learn more.
open | download - CONTROLLER1.gif (40.4 KB)
Re: controller built on breadboard
March 17, 2009 06:12PM
The diodes see a peak current equal to the coil current, but they are only on for part of the cycle so the average current is quite a bit lower. So you will probably get away with it.
jbb
March 17, 2009 09:48PM
Hi there
There's nothing wrong with testing stuff on breadboard, but a couple of holes I've fallen down in the past are:
1) a loose connection can cause really weird behaviour - try wiggling things if you have trouble.
2) because the L298s operate in switching mode, they will generate some high frequency currents. You showed a 100nF and 100uF capacitor pair across the 12V rail, which is good, but I'd put a pair (100n + 100u) right up close to the power supply pins of each L298 (i.e. 4 capacitors on the 12V rail). Some circuits I've tested on breadboard have behaved very strangely because the caps were too far away from the switches.
3) your breadboard might get a bit upset if you drive 4A through it...
Good luck.
jbb
Edited 1 time(s). Last edit at 03/17/2009 09:50PM by jbb.
March 18, 2009 02:09PM
I usually breadboard new circuits that I haven't built before, before I move them to perfboard or PCB. I've pushed breadboards up to 6 Amps before they started melting so it should be able to take 4 Amps. I would definitely put the caps on that jbb mentions and definitely heat sink the 298s. The diodes will be fine unless your motor shorts out and it's easier/cheaper to replace the diodes than the 298.
I would also recommend moving the whole circuit to perfboard or veroboard. Point
to point wiring isn't the greatest thing in the world, but it is more stable than being on a breadboard.
Anonymous User
March 26, 2009 09:32AM
Thanks for the comments!
I've implemented your suggestions and also moved everything onto a tin can and silicone caulk manhattan style setup, details once I've gotten them drawn out and such.
April 17, 2009 11:42PM
I cant say I've ever melted a breadboard... you should be proud Cris =-)
