Can someone help me to understand how the hall-o board is supposed to be connected to RAMPS? The main page in the reprapwiki literally says to just connect it - no guidance whatsoever.
The text seems to indicate that the normal way to install it is to use its digital mode, but again that is not clear.
Also, the test indicates that the
signal is what changes as the magnet distance changes, but the photos show connection being made to the
stop connection point.
What I THINK I get from the wiki is to connect (v, gnd, signal) on the RAMPS to (5v, gnd, stop) respectively on the hall-o. And then I need to set the endstops as inverted in the marlin configuration.
Is this correct?
Thanks
