hall-o connections
Posted by jbernardis
hall-o connections
July 09, 2013 12:26PM
Can someone help me to understand how the hall-o board is supposed to be connected to RAMPS? The main page in the reprapwiki literally says to just connect it - no guidance whatsoever.
The text seems to indicate that the normal way to install it is to use its digital mode, but again that is not clear.
Also, the test indicates that the signal is what changes as the magnet distance changes, but the photos show connection being made to the stop connection point.
What I THINK I get from the wiki is to connect (v, gnd, signal) on the RAMPS to (5v, gnd, stop) respectively on the hall-o. And then I need to set the endstops as inverted in the marlin configuration.
Is this correct?
Thanks
Re: hall-o connections
August 19, 2013 05:52AM
Im just installing hall-o endstops as my first ever endstop - possibly a bit too ambitious! Did you ever get this sorted with Marlin? I have no idea why my mendel doesn't appear to register the endstop and just goes smahing into it!?
Any help would be brilliant - im so close!
Cheers,
K
