The second link is correct. You connect the normally closed contacts between the input and ground. There needs to be a pull up but often just the internal pull ups in the chip are used. They need to be enabled in the firmware.
marlin configuration looks like this:
// Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
www.hydraraptor.blogspot.com]
