Re: RAMPS for Due! October 22, 2014 04:36AM |
Re: RAMPS for Due! October 23, 2014 04:32PM |
angelo
... and in 2-3 years 32-bit becomes a Standard for reprap or 3dprinter
Re: RAMPS for Due! October 28, 2014 01:36PM |
Re: RAMPS for Due! October 29, 2014 01:30AM |
Admin Registered: 14 years ago Posts: 7,284 |
Re: RAMPS for Due! October 29, 2014 06:20AM |
Re: RAMPS for Due! October 29, 2014 10:18AM |
Re: RAMPS for Due! October 29, 2014 10:22AM |
angelo
@dc42 Duett, ...
Also I am a friend, that I like to give the electronic 12 Volt and the Heatbed + Stepperdrivers (1/128) 24 Volt.
(So it is possible for no extra cooling fan for Electronic needed+1/128 RRD Silencioso a large alu-cooling so also no cooling need for Nema17 since 2A)
Re: RAMPS for Due! October 29, 2014 10:34AM |
dc42
Do you think 1/128 microstepping offers any significant advantages over 1/16?
Re: RAMPS for Due! October 29, 2014 10:43AM |
Re: RAMPS for Due! October 30, 2014 04:07PM |
Re: RAMPS for Due! October 30, 2014 04:52PM |
Re: RAMPS for Due! October 30, 2014 05:58PM |
Re: RAMPS for Due! November 02, 2014 08:51PM |
Re: RAMPS for Due! November 03, 2014 12:33AM |
Re: RAMPS for Due! November 03, 2014 12:59AM |
Dust
Presuming "cxandy" is the reseller or the maker I have requested source files be published somewhere...
Re: RAMPS for Due! November 03, 2014 01:09AM |
Re: RAMPS for Due! November 03, 2014 01:17AM |
Dust
That cct says that your still using the same mosfets as the original ramps, which im told will not work for 3.3v logic, unless you voltage shift back to 5v, and there is no cct for that...
There are also two additional jumpers that aren’t documented (one looks to disable D1)
Re: RAMPS for Due! November 07, 2014 10:37AM |
Re: RAMPS for Due! November 07, 2014 10:58AM |
jaguarking11
Just to clarify, what kind of firmware would support the DUE/Ramps combo? I have not seen much if anything support that particular setup. Anyone? I would love to try this thing at some point.
Re: RAMPS for Due! November 07, 2014 11:00AM |
powool
jaguarking11
I've been using repetier on my Due/RAMPS-FD with no serious problems. I also had tried aprinter, which I chose not to use - I think because I wanted to use repetier host, and obviously that works better with their own firmware.
To make my RAMPS board work, I had to modify the circuit board AREF pullup - I don't know if there is simpler way to do that. That happens if you try to use 5V digital logic, which I had to use because I am using external stepper motor drivers that require 5V logic. If you're just using 3V logic and DRV8825 boards or whatever, you probably won't need to.
Re: RAMPS for Due! January 14, 2015 01:44PM |
Re: RAMPS for Due! February 15, 2015 06:28AM |
cxandy
The Chinese modified can worked properly. Firmware support Repetier (due) and Marlin (due).
Here is a link [www.aliexpress.com]
Re: RAMPS for Due! February 15, 2015 06:40AM |
nicksears
Does the "smart ramps" have a due-compatible firmware with support for this board (408) yet?
Can I just add this to bobc's firmware? I just got my smart ramps, I'll try it when I get a chance.
I see the SD card should work, does the standard LCD/SD card reader combo work? (I'll solder the aux-4 header pins)
Also the same question for the rrd fan extender?
Re: RAMPS for Due! February 19, 2015 08:22AM |
Re: RAMPS for Due! July 22, 2015 06:19PM |
Re: RAMPS for Due! July 22, 2015 10:47PM |
Re: RAMPS for Due! July 23, 2015 08:05AM |
Re: RAMPS for Due! July 23, 2015 03:00PM |
Re: RAMPS for Due! July 23, 2015 03:26PM |
Btw. thanks for the small hint in your fork formthe fullgraphic. Just got mine to work for the RADDS.| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: RAMPS for Due! July 23, 2015 05:36PM |
