Re: RAMPS for Due! December 16, 2013 07:34PM |
Re: RAMPS for Due! December 16, 2013 07:54PM |
Re: RAMPS for Due! December 16, 2013 10:26PM |
Re: RAMPS for Due! December 17, 2013 01:03AM |
Re: RAMPS for Due! December 17, 2013 01:08PM |
Re: RAMPS for Due! December 17, 2013 02:09PM |
Cefiar
Problem with the 74HCT and 74ACT parts is that they're 5V logic only from what I have read (they're +5V with +/-0.5V supply), and 3.3V won't register as a logic "High".
If someone can point me to anything that says different, I'm happy to concede the point. This was based entirely on a 10 second Google search and looking at 2 spec sheets.
Re: RAMPS for Due! December 17, 2013 02:30PM |
Cefiar
Regarding the outpus being on when VCC has no voltage:
This is due to the way the pull-up resistors are hooked up and the fact we're using N channel FETs to drive more N-channel FETs.
Basically with no input on the gate of the DMN2075U's (the ones matching outputs 1-4), they are left in their open state. This means that the gate on the IRLB8743's gets all of +VGATE, switching it on.
This basically means that the existing Dual FET arrangement is broken by design if the 3.3v supply fails. :/
Re: RAMPS for Due! December 17, 2013 05:50PM |
Re: RAMPS for Due! December 17, 2013 06:22PM |
Cefiar
The only issue I see is that with all the specs I've seen on all HC/AC/HCT/ACT, logic "High" is considered anything from 0.5x (typical) to 0.7x VCC (the guaranteed limit at the temp specs of the package - -40C to +85C). At 5V, that means between 2.5v (typ) <-> 3.5v (max). This means as long as we're within the typical window (which never seems to be 100% defined on these things) we should be OK.
Re: RAMPS for Due! December 17, 2013 07:39PM |
Re: RAMPS for Due! December 17, 2013 09:20PM |
Re: RAMPS for Due! December 18, 2013 06:04PM |
uncle_bob
Of course if you *do* have a 7805 in there, that will make driving opto isolated stepper controllers a bit easier .... (yes that's a turn into the ditch and over into a whole other design). My only real point begin that extra +5 current can be handy to have.
Did the Microchip TC4426/7/8A's get looked at as drivers? You could run them off of +5 to +18V and still drive them (barely) with 3.3V logic (0.8 to 2.4V switch). They are reasonably cheap for driving a couple of FET's (70 cents for a dual). They are legit FET drivers with massive output capability. You would loose the built in "kill" capability that the tri-state buffer gives you with the duals in 8 pin dip packs. There's only so much they cram into them ....
[www.microchip.com]
Re: RAMPS for Due! December 18, 2013 06:21PM |
Re: RAMPS for Due! December 18, 2013 06:28PM |
commit d03338f50022aa99abe64a4e7b85a0ea21731da6
Author: Bob Cousins
Date: Wed Dec 18 22:42:30 2013 +0000
RAMPS-FD schematic: remove some redundant pulldowns;
add some explanatory notes;
update PDF
commit 1f6033e6de049db5228018c25bbc595a0df1a7aa
Author: Bob Cousins
Date: Wed Dec 18 22:20:43 2013 +0000
RAMPS-FD schematic changes:
#3 replace C301, C302, C303 and C501 with ceramic 0805;
#4 change endstop connectors to 6x1 and 6x2 to allow key position
#9 change E-STOP connector to KK type;
#18 add 10k pulldowns on heater outputs from CPU
#19 change E-STOP buffers to HCT type to always drive FETs at 5V and remove inverting drivers on heater outputs;
#20 add 24LC256 I2C EEPROM
Re: RAMPS for Due! December 18, 2013 06:57PM |
Re: RAMPS for Due! December 19, 2013 09:55AM |
bobc
Re: RAMPS for Due! December 19, 2013 06:17PM |
Re: RAMPS for Due! December 19, 2013 07:04PM |
Re: RAMPS for Due! December 19, 2013 09:28PM |
Re: RAMPS for Due! December 19, 2013 11:39PM |
Re: RAMPS for Due! December 20, 2013 04:17AM |
Re: RAMPS for Due! December 20, 2013 07:24AM |
Re: RAMPS for Due! December 20, 2013 08:06AM |
Re: RAMPS for Due! December 20, 2013 10:44AM |
Cefiar
I'd also considered replacing the 12V reg with a 9V reg (7809). This still gives a reasonable voltage for gate drive (much further up the drive elbow than 5V), and is more than adequate for running the Arduino (taking even more voltage drop away from the Arduino regulator under the shield, and thereby reducing heat generation under there - which could eventually be a problem). It also removes the need for the 12/24V jumper, as it'll always be on regardless. It'll require a heatsink if you run it off 24V, but the same was true for the 12V reg. Also, this gives a 3V margin at 12V, so the reg will run reliably (if not, we can always use a 7808 to get an extra volt overhead, at the expense of drive voltage).
Re: RAMPS for Due! December 20, 2013 10:45AM |
uncle_bob
There's a lot of room between the near ms turn on speeds with a weak pull-up resistor and the 10's of ns you might get with an uber driver on the FET. I would not cost reduce the series gate resistor out of the design.
Re: RAMPS for Due! December 20, 2013 11:38PM |
Re: RAMPS for Due! December 21, 2013 08:38AM |
Re: RAMPS for Due! December 21, 2013 09:24AM |
Re: RAMPS for Due! December 21, 2013 09:46AM |
Re: RAMPS for Due! December 21, 2013 10:52AM |
