Adjusting Stepstick A4988 steppe motor driver
Posted by calad
October 28, 2013 02:33PM
Hi. I have prusa i3 and those drivers. On which pin do I measure voltage? There are couple threads about this but they are outdated and links are not working.
And extra question is what should be level of voltage? I was planning to set it on 0.4V.
Re: Adjusting Stepstick A4988 steppe motor driver
October 28, 2013 05:21PM
Put one meter lead on the 4988's potentiometer and the other (for safety) on the negative of the 12v power supply terminal block. Rotate the pot to alter voltage. 0.4v is a good start although some have to be set up to around 0.8v.
_______________________________________
Waitaki 3D Printer
October 31, 2013 11:31AM
Thanks!
