Gen 7 board, AVR 1.5 board, steppers not turning/working November 28, 2013 11:38AM |
Re: Gen 7 board, AVR 1.5 board, steppers not turning/working November 28, 2013 10:03PM |
Re: Gen 7 board, AVR 1.5 board, steppers not turning/working November 29, 2013 08:00AM |
uncle_bob
To put it simply, none of your motors run no matter how you try to run them. Is that correct?
Does your hot end / heated bed heat up properly?
Is this a printer that was working up and working?
Assuming the hot end and heated bed work, none of the motors work at all, and the printer once worded - first check would be to make sure the firmware reflects the hardware. Put another way - does configuration.h have all the proper stuff for your board.
Re: Gen 7 board, AVR 1.5 board, steppers not turning/working November 30, 2013 10:02AM |
