Powering up a xbox 360 -S- power supply
Posted by Yvan
December 10, 2013 01:03AM
Hi Everyone,
I've got an xbox power supply for the xbox "S", it is only rated at 135 watts. More than enough to supply the RAMPS and steppers. I've cut off the twin barrel connector plug, and found four 18 guage wires inside.
There is 5 volts between the red and white wires, with the red being positive. The two other wires are green and black and show no voltage. The status LED is amber(or "Oranger" as the label says) so it is in stanby mode.
Does anyone know which wires I would need to connect to get the 12 volt side of the power supply to turn on?
Thanks!
Yvan
Singularity Machine
Re: Powering up a xbox 360 -S- power supply
December 10, 2013 01:37AM
Have a look at: [cwackduck.com]
The person who wrote that used a normal supply with a "Slim" adapter, but the procedure should be the same, and I'd also hazard the colours are the same, from your description.
Hope that helps.
December 10, 2013 11:16AM
Thanks, that's exactly what I was looking for!
Yvan
Singularity Machine
