Usb to ttl cable for only US$ 3
November 19, 2009 06:18AM
Hello:
This is a link of the project
[www.uchobby.com]
Bye
Re: Usb to ttl cable for only US$ 3
November 21, 2009 08:15PM
hey now this is useful! i recently got a full series 3 kit and steppers from makerbot but forgot the damn cable. shipping is about $30 to australia, so would have cost me $60aud for a single cable.
good find. +1
November 22, 2009 07:33AM
ooo, found an old motorola cable that looks promising, it has six wires in it, well 5 and a shield, so will have a crack at this. not entirely sure what i'm doing but can't really lose...
November 22, 2009 12:00PM
They're only 3.3v, don't know if they could be used for ICSP programming, plus they don't have RTS or CTS signals.
November 22, 2009 08:56PM
well i did say i don't know what i'm doing...
ok, next thing: is there a simple circuit i can build that will do what the cable does to which i can attach a usb socket?
and on another note, i think its an idea to put a usb socket on the motherboard, or at least have an option for it. i'm more into the mechanics of all this. second moment of inertia or flexure analysis i get, but i have little clue what the voltage levels are meant to be for ttl and why its different and necessary.
November 23, 2009 12:08AM
The mobile phone data cable hack is the cheapest where you can find the cables cheap.
You don't actually need RTS, CTS etc if you are prepared to operate the reset by hand (Press button) ocasionally.
You only actualy realy need RX, TX and Gnd connection.
A lot of the FTDI USB/Serial cables are 3.5v but 5v tolerant ie you can use them in both.
For the Mobile phone cables they are so cheap that you can afford to expend one or two until you get one that that is both 5v tolerant (I have yet to find one that isn't but haven't tried that many really).
If you are really stuck and have only a standard rs232 serial port available (9 or 25 pin) make up a converter board using something like a MAX232 RS232 to ttl converter chip. They are relatively inexpensive. But not as cheap as a hacked mobile cable once you total up all the parts and labour. I have used this route as well for talking to arduino based boards.
Hope this helps.
Necessity hopefully becomes the absentee parent of successfully invented children.
November 23, 2009 06:03PM
Would these be a good alternative to USB-TTL?
1) [www.robotshop.ca]
2) [www.robotshop.ca]
It almost seems like you can just connect 1) directly to the Motherboard, then use a USB to USB cable.
November 24, 2009 03:42PM
It is basically the same as an FTDI 3.3v USB Serial Cable without the cable.
December 01, 2009 09:21PM
There is another post some where here recomending a Nokia CA-42 cable.
I located one on Ebay for 99p / $0.5 including P&P waiting for it to arrive possibly this week or next from HongKong.
It had this Item number # 200403418373
Description USB DATA CABLE CA-42 FOR NOKIA 3100/3120/7360/7250/6822
I bought only one to try out but will buy at least a couple more so I can stop having to swap my $20 FTDI lead between my 3 non Audrino Processor boards.
With a little searching and some creative thought you can build your 3D printer for a lot less!
I will let yall know how I get on when it arrives.
Edited 1 time(s). Last edit at 12/01/2009 09:23PM by BodgeIt.
Bodge It [reprap.org]
BIQ Sanguinololu SD LCD board BIQ Stepcon BIQ Opto Endstop
BIQ Heater Block PCB BIQ Extruder Peek clamp replacement BIQ Huxley Seedling
BIQ Sanguinololu mounting BIQ standalone Sanguinololu or Ramps mounting Print It Stick It Cut it
My rep strap: [repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [repstrapdarwin.blogspot.com]
Web Site [www.takeaway3dtech.com]
