Re: RAMPS for BeagleBone October 04, 2014 06:10PM |
Re: RAMPS for BeagleBone October 04, 2014 06:59PM |
Re: RAMPS for BeagleBone January 04, 2015 12:05AM |
Re: RAMPS for BeagleBone January 04, 2015 09:55AM |
Re: RAMPS for BeagleBone January 04, 2015 11:38AM |
Re: RAMPS for BeagleBone January 04, 2015 05:08PM |
Re: RAMPS for BeagleBone January 04, 2015 05:26PM |
Re: RAMPS for BeagleBone January 04, 2015 06:23PM |
Re: RAMPS for BeagleBone January 07, 2015 12:15AM |
cdsteinkuehler
I am working on a BeagleBone Cape version of the RAMPS design, called CRAMPS. I have a stub page created in the RepRap wiki, and KiCAD design files are on github. The design is based primarily on the RAMPS-FD, with changes where needed for the BeagleBone.
The schematic is mostly complete except for assigning some I/O on the BeagleBone P8/P9 pin headers, which I will do based on the PCB layout (in progress). I would appreciate any design review or comments on the schematic.
Features are pretty much identical to the RAMPS-FD, except for the AUX expansion connectors. There is an SPI interface available that will work with the RAMPS-EXT extruder expansion boards, and an I2C header. Both the I2C and SPI headers are 5V tolerant, to allow easier interfacing to existing 5V Arduino add-ons. I plan on using pass-through connectors to support additional expansion, so the large AUX4 connector has been removed, and the AUX2 analog connector has been modified to allow direct interfacing to a 4-wire resistive touch-screen.
Questions and comments welcome!
Re: RAMPS for BeagleBone January 07, 2015 04:27AM |
Re: RAMPS for BeagleBone January 07, 2015 06:26AM |
Re: RAMPS for BeagleBone May 03, 2015 08:40AM |
Re: RAMPS for BeagleBone May 03, 2015 08:56AM |
TomWS
Looking at the Rev. V2.1 schematic, I see you have provision for a Cape Identification EEPROM. Is this necessary for the latest MachineKit image to recognize the cape? If so, is the EEPROM contents documented somewhere?
Re: RAMPS for BeagleBone June 15, 2015 02:59PM |
Re: RAMPS for BeagleBone June 15, 2015 03:01PM |
Re: RAMPS for BeagleBone June 15, 2015 03:04PM |
Re: RAMPS for BeagleBone June 15, 2015 03:07PM |
Yellobello
Other questiion:
When I would use Machinekit togehther with the BBB.. will it be realtime linux pulsing the stepper drivers straight with the CPU´s I/O or is it using the separate microcontrollers for this task?
Re: RAMPS for BeagleBone June 15, 2015 03:11PM |
Re: RAMPS for BeagleBone June 15, 2015 04:14PM |
Re: RAMPS for BeagleBone May 08, 2016 01:34AM |
Re: RAMPS for BeagleBone January 14, 2018 09:33AM |
